Old 07-13-2006, 09:13 PM
cjensen's Avatar
cjensen cjensen is offline
Default Fuel return to 1st bay okay??
My tanks are done, and I've decided I should've put in a return line, just in case I need one. Since they are done, the only option I see is to run the return to the first bay. I won't have access to clean out metal chips that would fall in to the second bay if I went that far.
Is this ok?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 07-13-2006, 10:22 PM
idleup idleup is offline
I just got done doing this. I also was worried about metal chips in the second bay. After talking to Dan C. he had a great idea that worked very well. I flushed the tank with water. I filled it with about a gallon of water and sloshed it all around. The metal chips came out easily. Anything left over will get stopped in the fuel filter.
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
