Hartzell prop question
The Hartzell CS props come with four spacers for the four bolts that the rear spinner baffle plate mounts to. These set the position of the rear baffle relative to the front baffle and make it fit the 13" spinner correctly. According to the spinners mounting instructions, the Hartzell props supplied by vans have a specific length spacer (called S-604). My prop did not come from Vans and the spacer appears to be too long. I could put them on a lathe and trim them down or just replace them with some AN washers instead.
My qustions is, does anybody with a Hartzell prop (bought through Vans) currently have the spinner off and could measure the length of those spacers?
Is there any reason not to use steel washers (probably 3) instead of aluminum spacers?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
