the short answer is, it depends. I don't know anything about those light strips. depends if the LED's are wired in series or parallel. IF they are parallel and the power and ground run the length of the strip there should not be any problem as long as the current limit of the connector is not exceeded. If the led are in series then the resistance is dependent on the number of LED's so daisy chaining them would decrease the light output of the LED's.
from a quick look at the pictures it looks like they are power and ground on the top and bottom and control for the two inside lines, and the LED's are in parallel, dependent on current totals It looks like it should not be a problem, but without looking at the schematic that is only a guess.
bob burns
RV-4 N82RB
