Old 10-27-2012, 12:42 PM
Michael Burbidge Michael Burbidge is offline
Default Wiring at the magneto...
My engine has slick mags. I've looked around a bit and cannot find information on which terminals on the mag are for what. I understand and have read the information about how to wire the mag to the switch, etc. I just don't know which screws on the magneto are for ground and which for the p-lead.
Here's a picture of my magneto. I've labeled each of the screws with what I think they're for.
I'm guessing the nut with the fabric washer is where I connect the p-lead. I've labeled that P-Lead. The screw marked GND is actually marked GND on the magneto. I'm guessing that is ground and where I would wire to ground on the mag. The one that confuses me is the one which I've labeled "Unknown". What is that for?
The screws appear to be torx drive. Do you happen to know what size?
Thanks for the help,
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 10-27-2012, 12:54 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Don't worry about "unknown"
The other two are correct.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-27-2012, 12:58 PM
Jim P's Avatar
Jim P Jim P is offline
Default Mag Wiring
Michael, your UNKNOWN is just a vent cap, nothing goes there. Assuming you have a shielded wire, you can use the ground to ground the end of the wire shield.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 10-27-2012, 02:54 PM
Default Securing p-lead...
Thanks.
One more question. Sometimes I'm not sure how to secure a wire firewall forward. This is one of those times. These are no other wires in the near vacinity to help secure the p-lead. Here's a picture. It seems like that 20 awg wire would break after awhile. Suggestions?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 10-27-2012, 04:24 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Wire support
Hard get a "perspective", but it looks OK. You might use shrink wrap around the leads to provide more flex support. I didn't use anything less than 18ga because of support reasons and the ability to get a good crimp on lug connectors.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 10-27-2012, 05:03 PM
floridawing floridawing is offline
Default Hello
Hello, PM sent
Old 10-27-2012, 05:07 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Looks okay.
A good idea to leave some slack for the engine to move a bit in the mount without tearing everything apart.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 10-27-2012, 07:04 PM
brad walton brad walton is offline
Default Switch
Remember when wiring the magneto to a switch, off or open on the switch will be ungrounded at the magneto, and thus the magneto will be hot. On or closed at the switch will allow the magneto to be grounded and not producing spark. I made that mistake initially.
Old 10-27-2012, 07:59 PM
cln1owner's Avatar
cln1owner cln1owner is offline
I would also suggest a rubber boot on that P-lead terminal.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 10-28-2012, 06:13 PM
N427EF N427EF is offline
Default Unknown Vent
The unknown Vent port can be used to hook up a fresh air hose.
Rather than just direct a hose onto the housing of the magneto, take the cap off and direct the cooling air right into the magneto where it does the most good.
If you remove the cap you will see a nut of sorts with 6 holes in it.
I removed this nut drilled out a hole large enough to accept a pipe nipple that would accommodate the inside diameter of a fresh air hose from the top of the engine plenum.
The pipe nipple is simply glued in with JB weld.
This magneto cooling idea is something that everyone seems to do at my airport. While most builders install some kind of air hose directed towards cooling the magneto, I think most of those are not very effective.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
