Old 10-25-2012, 02:26 PM
scsmith scsmith is offline
Default Alert: Vans 20006A oil cooler installation
I just posted this in a thread in the RV-10 section, but it is also relevant to other RV's that use this cooler, typically with the angle-valve IO-360-A engines.
I have this cooler on my RV-8 with an IO-360-A1A engine. I have OK cooling, but on really hot days, the oil still gets up to 225F -- 230F.
I found that when I installed the cooler, there are a series of small leak paths out the side of the cooler that reduce flow through the cooler some, that I should have sealed.
So, looking at the cooler, you can see that along the edge of each of the oil chambers, there is a small "u" shaped strip of metal that faces into the flow, creating a small channel that carries flow to the side edges. At the sides of the cooler, when it is mounted on a flat panel or bracket, these little flow passages are open and allow air flow out the sides. It is a very small area, but it is flow that does not flow through the cooler. So these passages should be sealed with high-temp RTV or some other method of sealing.
I just did mine, I'll report back as soon as I fly if I can tell the difference in oil temps. I'll see if I can get a picture too.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-03-2012, 05:48 PM
Default ten degree oil temp reduction
This is a thread bump. No one responded to my alert that you should seal the edges of your oil cooler with RTV. Maybe everyone else already does it.
Anyway, I flew today for the first time since doing it.
It was cooler aloft so not a definitive test, but I would say the oil stayed at least 10 degrees cooler on a long climb from sea level to 10,000 ft than I would typically see for the same conditions.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 11-03-2012, 06:01 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Well Steve, not sure if everyone does it, but I know that I do - it seemed sort of obvious to not let any cooling air leak out the gaps...
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-04-2012, 01:09 PM
flyvans.com flyvans.com is offline
and to add onto that,
our experience on our 7A shows that the same 20006A cooler actually cools better with the oil cooler shutter kit installed than without (which is kind of against common sense as the inlet area is made smaller)
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 11-05-2012, 02:04 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
How about some pictures? I sealed up a lot of things with RTV but a picture would be good to see if I missed something.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
