Old 10-25-2012, 04:04 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default Vans capacitance plates and Garmin G3X
Is the Garmin G3X able to read the fuel quantity using the Vans capacitance plates? Tanks are done and plates installed. Was originally going Dynon (with their adapters) but now taking a second look at the G3X.
Bob Markert
RV8 Fuselage
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 10-25-2012, 04:38 AM
newtech's Avatar
newtech newtech is offline
I originally had a Grand Rapids EIS4000 engine monitor with their Princeton capacitive fuel quantity transducers in my RV-7A. When I converted to the G3X the Princeton transducers worked perfectly. Garmin's capacitive fuel quantity algorithm gives a very accurate linear fuel quantity display.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 10-25-2012, 05:25 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Yes, as long as you have a sending unit that outputs either a frequency signal or a DC voltage. As mentioned, the Princeton capacitive converter box works well, as do other units from EI, Westach, and Skysports. Click here for a previous VAF thread where additional details are discussed.
- Matt
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 10-25-2012, 05:38 AM
Brantel's Avatar
Brantel Brantel is offline
Bob,
I recommend that you get the Princeton capacitive converters that work with Van's plates. Get the one you can adjust the span on the input to get a good signal for the EMS system to read.
The Dynon converters are not sensitive enough to the small change in capacitance provided by Van's plates empty to full. This causes the voltage output from them to only vary a tiny amount compared to the range available. Dynon did not provide a way to calibrate them or to change the span on the input so the end user is stuck with what they gave em.
The voltage only changes 0.4 volts empty to full on my RV7 with Dynon converters. Many others have reported similar numbers. The range available is something like 0-5 volts.
The Dynon calibration routine even has problems with this because the change is so low between calibration points that the system does not think you added any fuel between steps of the calibration process. I am sure that other EMS systems have similar issues with this small change.
When I move to the G3X, I will be changing to the Princeton converters.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-26-2012, 06:42 AM
bobmarkert's Avatar
thanks for the info. I had read the posts on the Princeton capacitive converter but I thought it went inside the tank. Ill research them today.
Thank You
Bob
Bob Markert
Littleton, CO KBJC
2019 dues paid
Old 10-26-2012, 06:45 AM
Brantel's Avatar
Princeton also makes capacitive senders that do go into the tank.
They also make a converter box that does the same thing as the Dynon converter only better. It is better because you can calibrate the input to the actual capacitance change of your tank in order to utilize the full range of signal output to the EMS system for best performance.
You have to call em as they do not have a website that I am aware of.
Old 10-26-2012, 08:36 AM
jarvis jarvis is offline
Default Princeton
Anyone have that phone # handy--or know of a source to buy these units directly?
Jarvis
Purchased flying RV-7A
RV-7A emp finished, wings next.
Old 10-26-2012, 08:41 AM
Brantel's Avatar
Here is the info I have. Not sure if it is current:
PRINCETON CAPACITIVE FUEL LEVEL PROBES
3133 Madison Ave, Wyoming, MI 49548 (616) 243-8800
I think they are in the same building as GRT.
Old 10-26-2012, 09:07 AM
Default Thanks, Brian
Much appreciated.
Jarvis
Old 10-26-2012, 01:07 PM
Sig600 Sig600 is offline
Can you install these on a QB wing with the tanks already completed?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
