Old 10-23-2012, 07:24 PM
dbaflyer dbaflyer is offline
Default AN3 hardware bolt head identification
I pulled some bolts out of inventory for the aileron bell crank assembly. AN3-10A. They would not fit through the 3/16 inch holes reamed in the top and bottom assemblies. I tried another AN3 bolt and it fit just fine. The two bolts have different markings on the top. The bolts that fit have "A F C" and an "X" on them. The ones that don't fit have "OIDO" and an "X". Is there a difference in this hardware?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 10-23-2012, 08:35 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Note that standard AN hardware is not particularly precise. I think that the specified range for AN3 is 0.186" to 0.189". So if you've precisely reamed a hole to 0.18750", you will find a certain number of AN3 bolts that are within spec but won't fit.
That's why I usually drill AN3 bolt holes #12 or #11 depending on material and application.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 10-23-2012, 09:13 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Thanks, Bob K.
A #12 drill/reamer is 0.190 so it should fit all AN3 bolts...
Skip the 3/16 drill/reamer which is 0.1875...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
