  #11
Old 10-23-2012, 05:23 PM
Brantel's Avatar
Brantel Brantel is offline
They all leak, it is just where do you want em to leak.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-23-2012, 05:33 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Not really much of an issue...
In practice I have found water infiltration to be mostly a non issue in flight. The majority of water comes in when opening a wet canopy. When I wash the plane I put dry wash rags in the air inlets and I dry the canopy and top deck before getting in for a 'dry the plane flight.
In flight through extended rain I get a small amount of infiltration on the back of the sub panel around the hinges. From another post it looks like I could do a bit work here.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 10-24-2012, 08:15 AM
I wish I could find a solution for the entire length of this area; I just can't get any sort of weatherstripping to stay in this location. Eventually it ends up all wadded up outside the plane and I just pull it off.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 10-24-2012, 11:20 AM
Rupester Rupester is offline
Default Me too, Bob ...
I'm having the same "bunching up" problem. Haven't decided what to do about it.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 10-24-2012, 11:31 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default I'm not there yet
I want to build a tip up for visibility and access. I am wondering, would a piece of ceconite that's bonded where the seal goes and again on the underside of the canopy frame work? The stuff is really cheap, if you need to get in there just cut it out or un bond it with MEK. Have it go to a gutter, or some other "drain path" as the certified big manufactures call it. It doesn't need to be shrunk, U.V. protection is a not issue because it's not structural. Treat it with silicone spray. Freezing water may be an issue if it pools. Thoughts?
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
