Keep VAF
Going
10-21-2012, 03:57 PM
Jabiru 3300 RV-3
Just ordered my rv3 kit. Will mostly be using it for cross country trips. The jabiru is 120hp but is much lighter than the other suggested engines. Will I have to worry about my cg?
RV-3 ordered
10-21-2012, 04:33 PM
Yes. So why don't you just use an 150 Lyc?
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
10-21-2012, 04:35 PM
Having to build on tight budget. Can get a new jabiru with fwf for $24000
RV-3 ordered
10-21-2012, 04:46 PM
RV3 FWD
Suggest you give the UL Power a look
It is a fine power plant.
10-21-2012, 04:48 PM
You can get a used Lycoming for less....
I flew behind a Jabiru 3300 recently and was impressed by it. The only part I didn't like was its Aerovee carb. Can't see any reason to have one of those. But the engine was smooth and powerful, light and small. Started instantly.
It's roughly 80 to 100 pounds lighter than the Lycomings, and that's bound to introduce some CG issues. If you move the engine forward, you're moving the prop forward and that reduces stability. It's not exactly a slam dunk. But if you can bring it off, you'll find a number of people interested in it.
Dave
10-21-2012, 05:08 PM
The jabiru is highly supported and easily installed. Have been looking over the rv3 layout. Considering the ways to move the cg forward without having to relocate the engine forward.
RV-3 ordered
10-21-2012, 06:16 PM
...Will I have to worry about my cg?
Yes but since you will need a custom engine mount anyway, have it made longer
Your bigger issue will be controlling the high CHT's the Jabirus are becoming known for.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
10-21-2012, 06:37 PM
Moving the cg forward wont be too tough. If I were you I would extend the .032 front side skins, floor, and top skin. You have to cut all of these pieces to size anyway, so it won't take any longer to cut them longer.
Rob Holmes
RV-3B N59LG - Built, Flown, Sold!
Extra 300 N111XW - Partner, Flown, Sold!
RV-7 NxxxLG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
10-21-2012, 07:50 PM
Engine Choice
If you want to build light, you might consider Lycoming's new o-233 116 HP engine. It is a great engine, should solve CG issues and can use a factory supported engine mou t from Vans. I have one in an RV9 and it works great. Plane is light and nimble.
Jim Potter - Ramona, CA
RV9A Owner- landed it at Osh on yellow dot
Previous Owner of 1940 J3 Cub
Currently Building RV14a
jimpotter4@gmail.com
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight." - Elrey B. Jeppesen
10-22-2012, 12:23 AM
RV3 CG w/Jabiru engine
There would be a *severe* cg problem in a standard RV3 with an engine 80-100lbs lighter than a Lycoming.
With such an engine, the engine mount will need to be re-designed and the fwd fuselage possibly extended. Either way, you'll have a very different structure fwd of the cockpit, implying some serious structural analysis and design work. The flight characteristics could change drastically - the farther fwd the engine, the more different the inertial characteristics will be.
This engine will require an entirely new cooling solution, new cowling, baffling, fuel and exhaust systems. These secondary tasks alone will be quite expensive. Is there a propeller for the Jabiru with the pitch/diameter needed for the RV3's speed envelope?
In short, to install an engine that the aircraft was not designed for, you will become a true experimenter. I'm not trying to persuade you not to do this, just be aware that with a new untried engine installation, it will cost much more than you originally intend, and will take 2x (or more) time to do it.
good luck!
- Steven
RV3 builder/pilot
(700+ RV3 hours)
(... 1.5 more today!)
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
