Old 10-21-2012, 08:01 AM
Auburntsts's Avatar
Default IO-540 Vaccuum Pad Stud Size
Folks,
I want to add a standby alternator on my 540's vacuum pad but my rebuilt didn't come with any hardware for the studs. What' the stud size or the right metal lock nut to use?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 10-22-2012, 01:16 PM
mahlon_r mahlon_r is offline
Should be 1/4-20 threads.
Good luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 10-22-2012, 01:23 PM
Auburntsts's Avatar
Default Another issue
Thanks Mahlon for the info. A quick search of the usual suspects (ACS, Vans's, Wicks, etc) didn't turn up an AN 363-4 metal lock nut with coarse threads (20 vs. 28). Anyone have a suggestion? For those with vacuum pumps or alternators on that pad, what fastners are being used?
PP ASEL-IA
WAR EAGLE!
Old 10-22-2012, 01:42 PM
rocketbob's Avatar
Tractor Supply is where I get course thread hardware for engines. Buy it by the pound there. The stuff you buy there is better (Grade 8) than what Lycoming uses (Grade 5).
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-22-2012, 01:53 PM
rleffler's Avatar
rleffler rleffler is offline
I've been able to get some from NAPA in the past as well.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
