Originally Posted by Rick Galati
<snip>... In the view of the FAA, a (VFR) pilot is responsible to navigate in this case by reference to a current sectional or current TCA chart...
Since VFR Terminal Area Charts (TAC) came to be published (with roots dating back to the 1978 San Diego
PSA Flight 182 and subsequent 1986 Cerritos
Aeromexico Flight 498 crashes), I believed that TACs were required to be carried in the aircraft to fly in Class B airspace. I always carry current LAS, LAX, SAN and SFO TACs in the plane. I've always thought, "How could you safely navigate this busy airspace without it???"
My buddy John Manduca said "No, you don't need a TAC in the plane." I didn't believe him so I checked with AOPA and found out that John was right...
AOPA told me no charts were required to fly in, around or under the Class B airspace. However, you
must carry a
current chart if you are going to navigate a special route such as the Hollywood Park, Shoreline or Los Angeles Special Flight Rules routes. This requirement is stated directly in the TAC itself.
After 28 years of flying in Los Angeles' airspace, you'd think I'd of known this. You are never too old to learn
Rosie
