Old 10-19-2012, 09:04 AM
HIIFLY's Avatar
HIIFLY HIIFLY is offline
Default Andair Fuel Caps ?
Has anyone bought and used these retrofit caps. They Look Great and I am thinking of replacing my current Vans type .
Can you tell me the size of Hole that is left to put the Gas nozzel in ?
Is it Larger than the Vans retrofit locking type ? Thanks
14 planes owned ,11 bought ,3 built .
RV-8 N808H ,Sold
RV-6 Sold 😔
Old 10-19-2012, 09:45 AM
mike newall's Avatar
mike newall mike newall is offline
Easy to fit - Proseal.
Great to operate, silky smooth.
Plenty of room for all standard gas nozzles.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 10-19-2012, 12:07 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Have you had any issues with venting?
Is there enough room left with the pump in to see the fuel level?
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 10-19-2012, 02:11 PM
No issues with venting.
We only leave the tanks half full so we can fly 2 up and do aero's if we wish - always use a dipstick.
If you are filling to the brim, you can still gauge the level OK because you can't fill the tanks fast in any case due to slow drain down.
Donated in 2020
Old 10-19-2012, 03:18 PM
Aircraft Specialty Aircraft Specialty is offline
We have them in stock and do custom engraving on them if anyone is interested. They turn out awesome.
They are a great value, and a great product.
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
