Old 07-12-2006, 11:45 AM
SebsRV7A SebsRV7A is offline
Default Sealing Tipup canopy on rollbar?
I am ready to install the baggage compartment window on my tipup. I'd like to seal the plexiglass to the rollbar for water and noise. Can I use RTV on Plexiglass or something else. Clear material preferred. Thanks!
Sebastian Trost
RV-7A
almost done!!!!
Old 07-12-2006, 11:56 AM
Scott Will's Avatar
Scott Will Scott Will is offline
I was told you can use Lexel and it won't hurt the canopy. You can find it at Ace Hardware stores (didnt find it at my Home Depot).
On mine, however, I glued my window on so that should be enough for me.
- Scott
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 07-12-2006, 06:39 PM
JCN247DE JCN247DE is offline
Default Proseal works great for this
Take some proseal put it in a ziplock baggie and cut a small portion of the corner off. Roll it up to compress the proseal like a cake decorating icing dispenser.
You can apply a nice even bead of proseal along the joint and the stuff can be painted if you want. I did this around the outside of the rear glass as well after masking off the window with 3M electrical tape. It makes a nice paintable fillet that blends the skin to the plexi.
Jeff - 120hrs flying -7A see you at OSH!
Old 07-12-2006, 06:50 PM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Fuller's Ultraclear
I used Fuller's Ultraclear.
Aluminium and perpex safe.
Easy to use.
Pete.
PS. I would have used Lexel but it is not available in Aus.
P
Peter James.
Australia Down Under.
Old 07-12-2006, 08:44 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Needed?
If you do a Targa strip you won't need to seal this area. If you do use a sealer make sure you are installing for the final time!!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-12-2006, 11:04 PM
rv72004 rv72004 is offline
So the rear window can easily be sealed, any suggestions for the canopy itself. ie where it closes on the rollbar?
