  #11
Old 10-19-2012, 10:28 AM
smokyray's Avatar
smokyray smokyray is offline
Default Cool it!
Originally Posted by tomcostanza View Post
Hi,
Is the oil cooler that comes with the FWF kit adequate? Or do most builders use a different one?
Tom, I've had great success with these: http://www.aircraftspruce.com/catalo...techcooler.php
V/R
Smokey
Dues gladly paid in Iraq...
Gladly paid to DR anyway...
Old 10-19-2012, 12:05 PM
Rupester Rupester is offline
Default Oil Temp is a function of several things ...
Baffling integrity or the use of a plenum are just as important in oil temperature as the oil cooler. That's why the responses to the initial question vary from "too much cooling" to "insufficient cooling", even on the same model with the same engine. I have a Sam James plenum with the standard Vans oil cooler (Niagara?) and so far it appears my oil temps are too cool. I never see anything above 172F in OA temps of 65F and below.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
