Old 10-18-2012, 07:30 AM
dwilson dwilson is offline
Default How do you notch the panel for the altimeter adjust knob?
Finishing up my RV10 panel. I need to cut the notch in the panel to accommodate the adjust knob for the altimeter.
I already have the 3 1/4 inch hole punched. I am willing to use a file, but can't figure out how to mark the cutout exactly on the panel.
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 10-18-2012, 07:42 AM
FredMagare FredMagare is offline
I'd seen a drawing with angles and dimensions online but am unable to locate it now. I'd suggest fabricating a tracing stencil from thin acrylic available from Lowes/Home Depot first. Get it to fit the instrument, set it in place on the panel through the mounting holes, transfer the cutout to the panel, then drill/cut/file carefully to the marking.
Good luck!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 10-18-2012, 07:46 AM
DanBaier's Avatar
DanBaier DanBaier is offline
See http://www.craggyaero.com/Drawings/I...0Templates.pdf
Make a paperboard template where the notch works and transfer it to the panel. I used a dremel with a cutting bit and finished with a round file.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 10-18-2012, 08:10 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Easy
Cut the round hole and drill the mounting holes.
Put the alt. in and carefully trace with a metal scribe around
The area for the adjust knob. I then cut away the majority with
A metal blade jig saw and finish up the edge with a
Carbide 1/2" rotary in a drill. Bought the rasp from The Yard
Store. Came out perfect.
http://www.yardstore.com/browse.cfm/4,4447.html
Al Girard, Newport, RI
N339AG
RV-9
Old 10-18-2012, 11:29 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Some dimensions here...
Check them against your specific instrument though...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-18-2012, 01:23 PM
Default Sure appreciate the responses
You guys are great.
Duane Wilson
Central Oregon
