Originally Posted by McFly
I dont understand what the cowl scoop should look like. Should I be making a tube that extends from the cowl scoop mouth to just shy of the FAB mouth?
Yes. The procedure I used:
1) install cowl & FAB - stick in ruler to measure gap X" between the existing cowl lip and the front of the FAB.
2) Use hacksaw blade to cut foam block so that it is X-.25" deep - make it plenty wide and high though.
3) Glue foam block to back of cowl opening with 5 min epoxy/bondo whatever
4) Reinstall cowl then insert hacksaw blade through the opening and cut out a 'tunnel' through the foam. Then use files/sand paper to shape the tunnel to nicely match the FAB inlet. This only takes about 30 minutes. Remove cowl.
5) Lay up fiberglass inside the tunnel (bonding onto the existing cowl inlet). After fiberglass cures, trim off aft side using the foam as a guide. Then remove the foam with your fingers/hacksaw. You are now done with the fiberglass (except filling).
6) I split the inlet rubber seal into two parts. The top flatish part I attached to the FAB. The bottom U shaped part I attached to the cowl (with a little bit of inward 'preload'). It still seals quite tight, but it makes installing the cowl much easier than if all the rubber is attached to the cowl side.
