10-16-2012, 09:07 AM
Torquing Bayonet CHT Sensors
I am installing the AFS CHT sensors which are the bayonet style. They have a threaded nut to attach to the cylinder head and a pre-attached lead. The problem is, how do I torque these into place? I can't use a crow's foot as its almost flush with the cylinder exterior and the lead prevents the use of a socket. So I'm thinking I need some kind of open barrel socket.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
10-16-2012, 10:16 AM
1) Use a line wrench.
2) Use a crows foot, or
3) Do what I do and just use an open end at an angle with maybe another tool for leverage on the wrench.
Put a smear of nickel anti-seize on the threads first.
Actual repeat offender.
10-16-2012, 10:19 AM
4) Grind flats on a deep well socket, run the wires out the square hole and apply crescent wrench to flats.
10-16-2012, 10:42 AM
Ah, I was thinking perhaps something like this existed for nuts (this is for coax connectors)
RV-10
N928MT
Build Project Site
10-16-2012, 11:21 AM
I don't see why you're overcomplicating this. All it takes an open end wrench at an angle to snug them up.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
10-16-2012, 11:25 AM
I'll try to get a picture, but the nut is practically at or below the exterior of the cylinder's surface, so there's no room to get a crow's foot on there and torque per the manufacturer's recommendation. I'm not sure a wrench would fit perpendicular either.
RV-10
N928MT
Build Project Site
10-16-2012, 11:39 AM
I've done it oh, about a hundred times. Forget the torque specifications, it just needs to be snug. You just screw it in, angle a wrench in there, snug it down, done move onto the next one.
N8155F C150 flying
10-16-2012, 11:48 AM
Gotcha, sounds like exact torque not required - just the usual Good And Tight approach. Thanks.
RV-10
N928MT
Build Project Site
