I have found that many Air FlowPerformance pump andfilter units willsooner or later have the "O" ring in the presure relief valve swell and stick, causing high fuel pressure readings, usually followed by a quick drop to normal when the valve is finally pushed off the seat. This can be remidied by replacing the "O" ring. Some installations read the fuel pressure off the line at the fuel pump, reading "un-metered pressure", some read at the flow divider, or "metered" presure. If you are reading metered pressure, there is no indications that the relief valve is sticking.
Also, anyone needing a condition inspection, pre buy, transition training, BFR or a Certificate of Airworthiness ( Northwest USA) please e mail or call!
Gary Brown (503) 269-3907
gdbrown@minetfiber.com
