Old 10-15-2012, 08:45 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default OAT Location
Hi All
I am installing a new EFIS and I need to locate my OAT sensor. Can I install it in the lower wing root fairing and receive a reliable reading?
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 10-15-2012, 09:09 AM
db1yg's Avatar
db1yg db1yg is offline
Hey Dayton,
I would expect the wing root fairing to pick up some of the radiant heat from the cowl. I have two OATs and know that the NACA picks up about 6 to 8 degrees f. from the cowl and I would expect the fairing to also pick up some--although not as much. I tried the NACA, the tail fairing under the HS, and finally settled on the first available wing access panel. This also gave me easy access. It proved to be out enough to avoid any engine heat and shaded from direct solar.
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 10-15-2012, 10:00 AM
rleffler's Avatar
rleffler rleffler is offline
I concur with Dave. I have one OAT on each wing, adjacent to the first wing access plate.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-15-2012, 10:31 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Hi Dayton,
Under the wing, outboard of any possible engine heat, is a great spot. That's where we put Tsam's (essentially mirrored the pitot position on the opposite wing. Another good one seems to be in the elevator horn access plate in the shade of the horizontal tail. I'd pick one of those for a retrofit - whichever gives you the least headache pulling wires.
I can't overemphasize the need for an accurate OAT in an EFIS airplane - so much of the cool stuff you get in an EFIS (like instant winds aloft) depend on TAS, which depends on OAT....you lose a lot when it isn't right.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-15-2012, 10:32 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Under the tailcone fairing...
I have mine under the fiberglass tailcone fairing... works spot on. If sitting in the sun it heats up and reads high but as soon as you start moving the air flushes ouy and it is works remarkably well at all speeds and temps.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 10-15-2012, 10:44 AM
JonJay's Avatar
JonJay JonJay is offline
Hey buddy.
I have two. One mounted as you suggest, under left wing root fairing towards the rear (EMS). One mounted under the right HS (EFIS). Both read withing a degree or two at all times.
When I had the EFIS sensor mounted in the NASA duct, it was consistantly high 10 deg, F.
FWIW
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-15-2012, 10:56 AM
DanH's Avatar
DanH DanH is offline
Mine like Paul's....mirror the pitot under the opposite wing.
Dan Horton
RV-8 SS
Barrett IO-390
