Old 10-14-2012, 07:23 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default fuel line question?
I plan to install a red cube fuel flow sensor between the fuel pump and carb.
I need to make up two fire sleeved hoses. AC spruce sells the hose and fittings. My question: Can I use Aeroquip 303 hose (non stainless wire mesh coated) vs the stainless mesh coated hose? The price is about half.
or does anyone know a source to have some smaller hoses made up?
Al Girard, Newport, RI
N339AG
RV-9
Old 10-14-2012, 08:34 PM
mannanj's Avatar
mannanj mannanj is offline
Default Hose
I made mine with 303 and fire sleeve six years ago. Probably about time to get TS flightlines to make me some new ones of braided steel/Teflon lining and fire sleeve.
I think the service life is twice 303 so the cost would be a wash. Correct me if I'm wrong Tom or Mel.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 10-15-2012, 08:36 AM
Mannan, service life of teflon hose is virually infinate---provided it isnt exposed to direct heat, or over bent. Even with firesleeve, its OD is smaller than 303, and that is a big advantange. Also----fuel with ethanol wont effect teflon like it can with a nitril liner.
Tom
Ridgeland, SC
Old 10-15-2012, 05:20 PM
Scott Hersha Scott Hersha is offline
Fuel with ethanol is an issue, but I think the only airplane engine approved for that is the Rotax. Teflon theoretically lasts forever but it is costly and difficult to work with - and very stiff. 303 hose is fairly cheap, flexible, easy to make with proper fittings, and the fittings are re-usable, so every 5 years or so, you build new hoses out of relatively cheap 303 (or similar) hose. Once youve done a couple, it only takes a few minutes to make a new one. If you want cheaper factory built hoses, including Teflon, try Earls Performance Products. They sell pre-built hoses or just the parts, including AN fittings.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
