Old 10-12-2012, 05:38 PM
crabandy crabandy is offline
Default Safetying flop tube
Finally got around to opening the tanks up on my rv7 to comply with the fuel pickup tube Safetying SB. Not flying yet I'm on the slow build. When I centerpunched the nut with a "good whack" as directed the nut holding the weighted pickup cracked. Kinda hard to see in the photo but the crack is in the top of the punch mark. I'm assuming I need a new one? If I do get a new one how have others safetyed the weighted end of the flop tube? Maybe I needed more finess?
Old 10-15-2012, 01:49 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Flop tube
I just took a picture of mine. I'll send a photo if you like. The old way was safety wire. Maybe they punch them now.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 10-15-2012, 07:06 PM
Sure, I'm not sure I want to punch the new one when it gets here. I thought about drilling the an fitting and using safety wire but not sure I want safety wire on the end that is flopping around the tank.
Old 10-16-2012, 06:09 AM
dav1111 dav1111 is offline
Super Moderator
You are mis-reading the service bulletin:
http://www.vansaircraft.com/pdf/sb06-2-23.pdf
The end of the flop tube ONLY gets punched to lock the nut. The Safety wire hole that is drilled goes at the bulkhead fitting.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 10-16-2012, 01:28 PM
Roger, punch mark (step 14) cracked the nut. I'm going to safety wire the top, debating If I want to punch the new one on the flop end to lock the nut or if someone has something different. Cover in Pro-seal, Directions have you proseal the threads on the pickup at the end?
