Old 10-23-2012, 09:17 AM
ggolden ggolden is offline
I don't know anything about the dimensions of the auto rollers, but if you want to put rollers in an aircraft crankcase you're going to have to modify the case to keep the rollers aligned.
Glen Golden
VP - Sales & Marketing
Superior Air Parts
Coppell, TX
Old 10-24-2012, 06:20 AM
Originally Posted by rocketbob View Post
They're ok if you don't plan on an overhaul. The roller lifters are $300 apiece and have to be replaced. x8 thats $2400 just in those particular parts at overhaul.
I have been toying with the idea of using standard automotive roller lifters with a custom cam grind and after talking to Lycon last week they have been doing this on experimental engines.
Superior's literature indicates their rollers are based on automotive technology. I was told by a reliable source the replacement cost is about $110, probably dealer cost.
All that and more being said, I've decided to go with a Superior IO360 with the roller technology, cold air sump and AFP FM150 with the purge valve. The engine will be assembled and tested by the BPE in Tulsa.
Also decided to go with a Catto prop again, if I can get one. They seem to be busy.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-24-2012, 08:04 AM
rocketbob's Avatar
Yep well aware of that.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-24-2012, 09:49 AM
659JR 659JR is offline
Default LIFTERS
I have both new and used Lycoming lifters in stock and they measure .8425
Jesse
Old 10-24-2012, 11:09 AM
rocketbob's Avatar
Jesse
Ok, thanks Jesse. Probably the most critical measurement is going to be the the slotted area so that its compatible with the existing oil passages. A larger diameter hole can be CNCed in the case such that the flat in the bottom that indexes the lifter can milled into the case. Obviously a different cam grind is in order, and Lycon already does that.
Could you measure the Lycoming roller lifter like it is in following drawing?
http://delphi.com/shared/pdf/ppd/pwrtrn/gas_vlvlift.pdf
N8155F C150 flying
Old 10-24-2012, 12:09 PM
Default lifters
I can forward some pics if you want but it looks like the Lycoming are quite a bit longer. They are 81.34mm in length. If you want some pics send me a e-mail. jesse@coairparts.com. Superiors are quite a bit different I hear but I do not have any to compare.
Jesse
Old 01-18-2016, 02:47 AM
flintstoneflyer flintstoneflyer is offline
So, did the Ford tappets work?
Old 01-18-2016, 05:25 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Thread drift question ?
I am building a new O320 / 150HP as we speak. I asked the engine builder about rollers and he said they were for more aggressive cam profiles and did not deliver any benefit for a well maintained Lycoming O3X0 cam.
So, what is the objective ( reason ) for pursuing these roller followers ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-18-2016, 09:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The reason is higher rate of wear, which is due to scuffing on the cam from a sliding motion of the flat facet tappet vs. rolling motion on the newer lifters.
There is also, best as I can remember at least, an issue with oil additives (zinc I believe) being removed from oil that comes into play also.
And, coupled that with the typical long time interval between usages on most planes.......................which is why I use Cam Guard additive.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
