Steering Link Wear/Failure
I have been using a Jantzi Link over the life of my RV-8, which is now approaching 250h. During the first 50h, I noticed that the pin in the TW was not engaging the arm, a phenomenon that made for some interesting landings. After doing a little research, I removed and cleaned the TW and the pin, and chamfered the edges of the pin, aiding in its egress from the cage. Over the next 100h or so, I found that I had to service the TW every 30h in order to ensure reliable operation. Then, I noticed that even after servicing it (and I tried all different lubrication modalities, including nothing) the problem would emerge. I tried different torques on the top-nut of the TW, thinking that the arm needed the slightest amount of vertical play in order to engage the pin, with no reliable result (they do call it experimental aviation for a reason).
Two weeks ago, I very nearly ground looped into the grass at my 50'x2000' airport while landing with a stiff crosswind. I confess that I had been aware that the steering arm was not engaging the pin in one direction very reliably - this was evident during the preflight inspection as a rudder that would turn independantly of the TW in one direction but not the other. I removed the steering arm and noticed that one of the shoulders of the pin slot had been very slightly worn, such that the angle was no longer very sharp. I replaced it with the 'T' type arm that came from Vans (along with the Jantzi spring) and the problem is solved.
Has anyone else had a similar problem? Having brought this up at one of those weekend lunches with a bunch of other RV'rs, I suspect that this is a widespread problem. I am thinking about switching links altogether to the Silver Bullet, but I am worried about the sturdiness of that steering arm.
Jon Weiswasser
RV-8 N898JW
Lincoln Park, NJ
