Old 10-10-2012, 04:53 AM
Capflyer's Avatar
Capflyer Capflyer is offline
Default Smoke System Pump
My homebrew smoke system pump Shurflo 8000-643-210 is shot and probably needs the diaphrams replaced after only a few tanks of smoke oil blown. The motor runs but no pumping action. This pump is 1.7gpm, 35psi, continuous running bypass pump, buna valves and geolast diaphrams.
I'm wondering which pump Smoking Airplanes uses on their systems. Can anyone help out with that number? I know it is a Shurflo but not sure which one.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-10-2012, 06:08 AM
Tony Spicer Tony Spicer is offline
Mike,
SA puts their label over the factory label, so it's impossible to read the part number. Used this in both my -3 and -4 with no problems. Available online or at your local West Marine. RV-4 install here.
Tony
Old 05-19-2014, 03:45 PM
Geico266's Avatar
Geico266 Geico266 is offline
Anyone share info on a smoke oil pump that works wells?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-19-2014, 04:02 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Using at Shurflo 8000-643-236 pump also in a home grown system. Been in use for a couple of years now with no issues.
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 05-19-2014, 04:05 PM
Capflyer's Avatar
The pump I ended up getting has been working well but I'll need to get the number off of it when I go to the airport tomorrow evening. Stay tuned.
Mike
JAMES AIRCRAFT.com
Old 05-19-2014, 04:46 PM
RV6_flyer's Avatar
The Smoking Airplanes pump is an off the shelf pump but has custom proprietary diaphragms and seals that will withstand the smoke oil.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-19-2014, 05:32 PM
It does? How about this pump from West Marine? Designed to do oil and ATF changes. Specs here.
Tony
Old 05-19-2014, 05:36 PM
Norman CYYJ Norman CYYJ is offline
I used a Facet pump similar to the one Vans sells but is made for diesel fuel and is higher pressure. Can't remember the model number or flow rate. I installed it in a F1 Rocket which is now in Germany. It made lots of smoke.
Old 05-19-2014, 08:12 PM
Low Pass's Avatar
Low Pass Low Pass is offline
http://www.systemacc.com/catalog/contactUs.php
These guys were *very* helpful with me on several occasions. Custom assembled pump with diesel resistant wetted pump parts. Help with troubleshooting later.
I believe (it's at the hangar) my latest version is the Shurflo 8000 series, 1.8 gpm, 60 psi with switch. I think(!) it has all Viton wetted parts. Threaded connections were mandatory. (No barbed cons for flammable liquid in my plane.)
Next version will be a 12 v submersible type automotive fuel pump.
Old 05-19-2014, 08:37 PM
deek deek is offline
I was Shurflo's VP of Manufacturing/QA for many years. What you need are Viton valves for the 8000 - definitely not EPDM and probably not nitrile. The Santoprene diaphragm should holdup fine for many years of "smoking". Viton diaphragms were developed for ag spraying applications but are less desirable if you can get the life you need from Santoprene.
The 8000 is an industrial pump and has numerous design changes from the potable water versions used in RV & Marine applications; if it were mine I'd use an 8000 - either a 60 or 100 psig version and avoid the 150 psig pumps.
Dick Kreidel
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
