Old 10-09-2012, 02:26 PM
AggieDon72 AggieDon72 is offline
Default King KN53 Wiring Schematic Symbol
HELP!! Having trouble understanding the King wiring diagram symbols.
Where two wires are to be joined together there are different symbols depicted.
One is a solid oval over the wire to be joined with a line under the oval attached to the second wire (pin). Are the wires simply twisted together? Confused since the used harness I purchased separates the wires with a shielded cable???? (Example: KN53 pins B & 15 connecting to KI209 pin 2 with the same symbol).
A second symbol is a dashed oval with (or without) a small circular point above and/or below the oval. (Example: KN53 pins P,13,R, & 14 connecting ti KI209 pins 3,9,12,& 6 on the indicator drivers). It seems these are all wired together......
Any education here would be appreciated. I can't seem to find any definition or help on the net. I have a .pdf drawing of the schematic if I can email it to a kind electrical wizard. Not sure how to attach here.
AggieDon72
Old 04-15-2014, 03:51 AM
przemekmac przemekmac is offline
Hi, I'm looking for pinout/installation manual for this radio. Can anybody share it for me?
