Chris I had ths same problem on my 7 gear. I had to polish the gear leg quite a while. I think you will find thet the axle is slightly out of round and the fit tighter at some places. This is a result of the heat treat process probably. I used one of the wheel bearings as a test fit part and emory clothed away until I could get it on (snug fit desired) just taking off the high spots as best I could. Probably took 30 minutes per axle, don't remember exactly. When done lube the axle with LP3 or similar to prevent rust. Now, my wheels slip on with a little banging with my fist, have to use a rubber mallet to remove them. Another thread on this subject exists somewhere on this site.
Larry
