Originally Posted by rwarre
Need to buy the AN tee fitting for the brake reservoir. My nylon fitting has started to leak. Does anyone have the Sprue part number?
Are you replacing the hoses as well? The Vans plastic lines won't work with an AN fitting.
If you are using/changing to SS lines with 37 degree fitting, then an AN826-4D is probably what you want. That is -4 fittings with 1/8 pipe on the run.
http://www.aircraftspruce.com/catalog/hapages/an826.php
