10-08-2012, 10:51 PM
Permatex - which one?
As part of installing my fuel drains (and the fairings I have for them), I want to use some sort of gasket-forming material rather than just EZ-Turn to ensure no leaks (because of the stack-up of drain, fairing and flange, I'm not entirely confident I can tighten the drain down enough to prevent a leak with just EZ-turn and the NPT threads fitting tightly enough). BUT...which Permatex? 1, 2, or 3 (aka "Aviation", per ACS' listing)?
What's the diff between these?
TIA, as always...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
10-09-2012, 02:35 PM
#2 is non-hardening and good stuff. Been around for at least 50 years that I know of. I've used it to replace the EZ Turn fitting joints on my red cube ... whose leaks have given me fits. I also used it on all the brake fittings ... no leaks there!!
I can't speak to #1 (hardening version maybe?) or #3.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Reason: Removed expletive
10-09-2012, 07:04 PM
I discovered #3 in 70's and used it to rebuild 100's of VW engines. I never had it leak. #3 does not harden and I plan to use it on red cube, so I hope the pros will respond with some real data. I want to know too.
BTW - it dissolves with alcohol.
Bill
RV-7
Lord Kelvin:
10-09-2012, 08:44 PM
Steve,
How long ya' been building?
Really, how long have you owned those tank drains?
Mine were 7 years old when I started phase 1 flying.
One started leaking like a sieve one day when sumping the tank. I took them both out and found both O-rings were cracked to heck. Had to replace.
Bill Pendergrass
ME/AE '82
10-09-2012, 11:08 PM
Just over 5 years building, and getting oh so close to being done now...so the wings are probably 3 or 4 years. I'll check the drains to see how the rubber gasket looks...thanks for the tip!
Santa Clarita, CA
#8,000
10-10-2012, 06:39 AM
Called permatex about which to use on screws for fuel gasket and was told #3 it has worked so far.
10-10-2012, 08:28 AM
I also used #3...and from reading the specs, I couldnt see a difference between #2 and #3...I just went with #3 because it says "aviation" on the bottle, which seemed good enough for me. Not flying yet so I cant report results.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/ WW 200G-CS/ SkyView/ Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
10-10-2012, 10:06 AM
#3 doesn't harden at all and is a thinner, more runny consistency than #2 which is more of a "sloppy paste" consistency. #3 is what was used on the threads of the #8 screws on the fuel gauge sending unit cover plates of 4 RVs that I know about, and have no leaks there after many years later (since build date of 2003 on my RV-6, 2004 on a friend's RV-4, 2009 on a friend's RV-10, and 2010 on the RV-8).
It resists gasoline excellently. I know that 100LL will not work to wash it off your hands, but a mixture of denatured ethanol mixed with a little MEK will remove it.
Neal Howard
Airplaneless once again...
10-10-2012, 10:20 AM
Not what you're asking but you should be confident that, indeed, you can.
10-10-2012, 02:43 PM
VAF Moderator
Ron,
The #3 you used will be fine for many years. I've been using the stuff since 2nd Grade.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
