10-08-2012, 07:17 PM
Light Speed Direct Crank install question
Can anyone out there using the LSE Direct Crank help me.
The mount that gets attached to the engine has to have holes drilled and tapped in the engine. but the prop flange is in the way. Does the prop flange have to be removed? I've looked at some pictures and it kind of looks like they might be able to be drilled thought the holes in the prop flange. I'm at home and can't look at it on the plane right now.
I'm planning to install the new Mini sensor but it has to have the holes drilled and tapped in the engine also.
Hoping someone can give me some insight, before I get back to the hanger.
Thanks!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
10-08-2012, 07:21 PM
You sure you don't have the holes already there?  You can drill through the flange hole.. you can't really remove the flange.. so short of splitting the engine that's your best bet. This is covered in the manual.. but again, only applies if you already do not have the holes in the case. For reference, my engine (built from an ECI kit) had the holes already in there ready to go..
Radomir
RV-7A sold
10-08-2012, 07:32 PM
As I recall, you have to press out one of the prop flange ferrules with a large C-clamp, then you can drill the hole where it needs to be. Use a progressive 3-tap set to tap the hole a bit at a time.
10-08-2012, 07:36 PM
Correct. Emphasis on the LARGE c-clamp. Get a collection of 1/2" sockets, you'll find a combo that works with the clamp. Also, you'll need a high strength bolt of the correct thread to push and pull against the insert.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
10-08-2012, 07:52 PM
The ECI cases are already drilled and tapped, assuming your XP engine is Superior I'd give them a call and ask about their cases.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
10-08-2012, 08:03 PM
Halls Effect Module broke
My engine does not have those holes, I was really hoping that they were there, but they are not.
The reason for the upgrade is because my Halls Effect Module failed, most likely from hormonics after 622 hrs.. The new Mini Sensor looks like a better setup. I sent my flywheel to Klaus to be machined and have the ring install.
Here's the picture of the failed module:
https://picasaweb.google.com/lh/phot...eat=directlink
Thanks to everyone that replyed. I have a good understanding of what I've got to do now. I have a buddy that owns a machine shop that I'll be calling for help.
I didn't think that the prop flange comes off but wasn't sure.
10-09-2012, 05:35 PM
Pictures
Ok, made to the hanger to look it over and here are some pictures does this look right?
After I remove and bolt bushing am I going to be able to drill a strait hole in the bosses?
10-09-2012, 05:47 PM
Make a drill jig that fits in the flange.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
10-09-2012, 05:53 PM
When I drilled mine, I made a template out of .032 sheet off of the direct crank sensor mount plate. I don't have the mini, maybe the same can be done with it. I started off with a #40. Remember, you will need long drill bits.  Oh, and on the large older style direct sensor plate there are crank tabs you need to use for centering up the sensor plate. Don't forget to break the tabs off when you're finished and ready to mount permanently. Klaus told be you need 4 out of the 6 bolts in the plate to the boss locations, some are easier than others to get too and line up drilling and tapping tools.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
10-10-2012, 05:42 AM
Great pictures.
I had the same issue installing mine. I made a jig and did the best I could.
I removed a bushing and made a jig.
After I got the holes tapped, the holes were a little off. I have to wallow out the holes in the mount a little. The only problem I ever had afterwards was that once when I removed it, this past week actually, since the mounting plate could move around a bit before tightening the 3 bolts, it turns out it is possible to get the mounting plate out of round just a little from the crank. This since you will remove the supporting tabs after you get it ready to install. THis meant that the pickups on the flywheel did not all work on reassembly. A dial caliper made it easy to get the plate concentric with the crank.
