Old 07-10-2006, 10:19 PM
mistergerf mistergerf is offline
Default Start procedure for IO-320 AFP Fuel Injection
Working on my "Normal Procedures" for my RV-9 / Aerosport IO-320 / AFP Injection.
Would any of you like to share your startup procedure if you're flying the AFP Fuel Injection system. Is this about right ?
- Mixture full rich
- HP fuel pump on
- Throttle wide - wait 3-5 secs
- Throttle 1/4" open
- Start
- HP fuel pump off
Appreciate your comments ...
Old 07-11-2006, 05:50 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I generally turn the boost pump on for about 5 seconds then shut it off. Otherwise, your procedure looks okay for a cold start.
Now hot starts are another deal. There was a thread here about a month ago on various hot start procedures. It generally depends if you have the purge valve installed or not. You might want to do a search for that thread.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 07-11-2006, 07:19 AM
zav6a zav6a is offline
Default AP Starting
Looks good, however, if you have a purge valve and used it at shut down, I've found that priming for up to ten seconds is called for.
Duane Zavadil
RV6A
AP IO 320
Old 07-11-2006, 06:57 PM
markscogg markscogg is offline
Default Starting with AFP - no purge valve
Cold
- Mixture full rich
- Throttle wide open
- HP fuel pump on until pressure passes 25psi
- HP fuel pump off
- Start
Hot
- Same except you flood the engine so:
- HP fuel pump on until pressure passes 20psi
- HP fuel pump off
- engine will be slightly flooded so Mixture to idle cut off
-Throttle wide open
- Crank until it catches
- Pull throttle back and mixture in
Mark Scoggins
Charlotte, NC
RV-6 bought,flown and sold.
Rv-4 bought, flown and sold.
