Some filing will be required. Keep in mind that some rocker box gaskets are wider than others. OEM gaskets typically protrude only slightly beyond the cover while some of the "better" silicon gaskets are not only thicker, but wider.
If you have not done so already, I would recommend changing your gaskets now to silicon. Again, some match the OEM cork width, some are quite a bit wider.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
