Old 10-08-2012, 07:21 AM
Daniel S. Daniel S. is offline
Default MK-319-BS rivet
Hey all-
Does anyone off hand know of a rivet similar to the MK-319-BS (7/64 or 3/32) flush-blind-cherry rivet with a longer with a grip length? the MK -319-BS grip length is only 1/8". I need something slightly longer & can seem to find such a rivet without moving up to a #4 rivet.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
-Electrical System Planning / Schematic Done.
-Wing Kit Delivered 09/13/12.
-Wings 95% Done Flaps & Electrical to go.
-Have got to order the fuse soon!!!!.
[/font]http://www.mykitlog.com/dschoning/
"This is a first-time event, and we're looking forward to it"... Chuck Yeager
Old 10-08-2012, 07:54 AM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Equivalent
Double post
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 10-08-2012, 08:00 AM
Default Equivalent?
Looking at the ACS chart, it would appear the next one up with a longer grip is cherry rivet 04-01955 or a SSD32BS "pop" rivet. The rivet diameter is the same at 3/32" but the grip lenght is .271 verses the .125 of the MK319BS. Just not sure if it is a flush one. I'm sure the experts on here can help out with that.
The link to ACS is :
http://www.aircraftspruce.com/catalo...errynrivet.php
Don
RV-8 build
DONE!
C-GLOV
Old 10-08-2012, 08:34 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
All the Pop Rvets in the world are listed and defined here - well not quite, but almost...
http://www.hansonrivet.com/w18.htm
MK321BS has a grip to 0.110 - Note the MK319BS has a real grip of only 0.090
Pick the other tabs on the page for other rivet construction...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-08-2012, 08:57 AM
Thank you Gill!!!
Now the quest to find where I can buy MK-321-BS rivets. I litterally only need a few. It looks like the only folks that have them are the wholesale supply houses... GRRR!
DANIEL S.
RV7-A (528KS)
-Empannage Done.
Old 08-23-2013, 12:03 PM
Traveler Traveler is offline
Default MK-321-BS Rivets
Daniel S
Have you found a source for a small quantity of MK-321-BS rivets?
