Old 10-08-2012, 04:04 AM
rwtalbot rwtalbot is offline
Default Ever wondered how well your pistons are balanced?
These pictures are from a set of pistons straight out of my Mattituck / ECI engine. The cylinders are being replaced at 347 hrs TTIS due to the AD. On a whim I decided to throw them on the scales I keep in the hanger. The pistons are as removed, with the rings still on and the piston pins in.
I'm pretty impressed the ECI logo in black paint is still visible on the piston wall. Sure makes you appreciate why reducing RPM results in better fuel efficiency with the inertia in these big pistons.
Cylinder 1 & 2
Cylinder 3 & 4
Richard Talbot
RV-7A
Sydney, Australia
Old 10-08-2012, 05:29 AM
Walt's Avatar
Walt Walt is offline
The plots here also tell the story of internal engine balance, the 2X blade rate corresponds to piston/rod balance.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-08-2012, 08:03 AM
bret's Avatar
bret bret is offline
The clean piston skirt shows good ring sealing, correct break in!
Old 10-12-2012, 10:26 PM
eddieseve eddieseve is offline
Very nice Richard, hope mine are doing as well.
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 10-12-2012, 11:31 PM
rhill rhill is offline
Default Balance
What is the +/- of the pistons,rings,wrist pins&caps in grams,I'm going through this now and I'm within two grams,2 even,1 one gram heavy,1 one gram light.
Matatuck had a huge inventory to pick through on there builds.If I need to bring the three down to the lowest one,Where do I remove the weight?Is there any advantage to the heavy weight piston,heavy wall pins over lighter Superior supplied Pistons/pins?
On a 911 engine I would move these heavy units to the rear near the fly wheel and keep opposing weights the same,Can I do that with a Lycoming?
Bob
Old 10-12-2012, 11:44 PM
Bob, I can't answer your question completely as I am only doing the cylinders. My new cylinders from ECI came with piston and rings. The pistons and rings were all weighed in the factory and marked on the box, balanced to the gram. If this is anything to go by, how much Mattituck would need to do on an ECI engine is questionable.
There is a lot more to balancing the bottom end than just weighing the components but I am sure it would be a good start.
Richard Talbot
RV-7A
Sydney, Australia
Old 10-13-2012, 07:00 AM
Mel's Avatar
Mel Mel is offline
It's been a while, but if I remember correctly, Lycoming's limit is 7 grams max delta.
Remember, this is a low RPM engine and while the better balanced the better, it's not as critical as on a higher RPM engine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-13-2012, 07:39 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
And nice low deposit pistons too
AA sent me your jug pictures...... Nice work! Makes all hose flat earth LAMEs afraid of heating humble pie.......CrowPie
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
