Old 10-06-2012, 09:10 PM
bhester's Avatar
bhester bhester is offline
Unhappy Light Speed Mini Sensor - anyone using it?
Anyone using the new Mini Sensor from Light Speed Engeneering?
It looks to be pretty much trouble free and easier to install than the origanal direct crank sensor.
http://www.lightspeedengineering.com...#Mini-Lycoming
The reason I'm asking and thinking about it is because my Halls Effect Module broke yesturday. I'm either going to have to pay for a repair or buy the updated Mini Sensor.
https://picasaweb.google.com/lh/phot...eat=directlink
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 10-06-2012, 09:43 PM
kevinh's Avatar
kevinh kevinh is offline
Dear long lost relative . Great photo - any theory from LSE on why it failed?
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 10-06-2012, 09:51 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
The mini certainly looks more robust.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 10-07-2012, 06:39 PM
bhester's Avatar
Red face Failed Halls Effect Module
I got an email from him today and this is what he said:
Can you measure the backlash of the gears by measuring how much the end of the remaining rotor can be moved back and forth when the gears are engaged?
I suspect that you have too much gear lash, obviously the Hall Effect module does not put any load on the rotor, all stresses come from torsionals of the crankshaft.
Both gears look fine don't know why it would just happen now. Haven't had a chance to see if I can get any kind of measurement.
I have 622 hrs on everything, it was doing fine one day and then the next it was not.
I am most likely going to switch to the Mini Sensor, it looks to be the better setup.
Old 10-08-2012, 09:14 AM
flion's Avatar
flion flion is offline
Wow, that is a total redesign of the current system. No more drilling the flywheel and the sensor mount is greatly simplified and improved. I'd give it a try except 1) I wonder how easy it would be to wire into an existing harness and 2) he doesn't have the price or a line for it on his ordering page. Still, it looks very good; the two things I really didn't care for on my LSE was the clunky sensor board for mounting (with poorly potted wire connections) and the fact that the sensor leads went to large D-sub connectors that needed to pass through the firewall. This looks like one of those concerns has been fixed.
EAA Technical Counselor #5357
Old 10-08-2012, 09:31 AM
kevinh's Avatar
Hmm - from looking at his instructions, the flywheel still needs to be drilled - but now just for the screws that hold on the new metal ring. (As opposed to putting the magnets into the flywheel itself).
