  #11
Old 10-06-2012, 11:08 AM
Av8torTom's Avatar
Default Snips
Snips all the way - VERY simple, VERY fast and accurate. I started out using my band saw and that worked quite well, but the snips were faster and easier. Finish up on a 6" Scotchbrite wheel. Be sure to use right or left hand snips as appropriate.
N677AT reserved
Superior XP O-320, 160HP
Old 10-06-2012, 06:22 PM
Default Snips, sander, file, done.
Thanks everyone for the suggestions.
Finished the ones for the rudder as described above.
Tried other things with no luck but a lot of fun -
Took a couple trials of the scoring technique, which I couldn't get to work for me. Apparently I'm missing something.
Went to the store and tried a paper cutter, sigh, they don't make them like they used to.
An old technique involving a chisel and a vice didn't work because the "good" part was the cut-off. It would take more tooling to get the stiffener to be airworthy this way.
I nearly made my own little shear. Didn't when I realized that snips would do the job in a flash. Turns out that it isn't so hard to do, though: a bit of wood, three scraps of 4130 (anvil, clamp and blade), a single bolt would do it plus a vice. Easier to merely use tools on hand.
I didn't use the band saw. Mine is somewhat aggressive (3/4 hp, 6.5 tpi blade) and using it for these cuts would take more effort to keep it good than snips would.
Thanks again!
Dave
Old 07-03-2013, 08:00 PM
fl-mike's Avatar
fl-mike fl-mike is offline
having just accomplished this, I can say without hesitation that a DiAcro 6" corner notcher is the bee's knees for cutting the taper and squaring up the ends. I picked one up a while back on Craigslist. Very clean and precise, and super fast.
Mike W
Venice, FL
N164WM
Old 07-04-2013, 11:52 AM
N804RV's Avatar
N804RV N804RV is offline
Repucci's method - exactly!
I haven't gotten that far yet with the "real" airplane. But, I was working on the airfoil practice kit from Van's which uses the same sort of tapered stiffners.
I don't have a band saw yet. So, I tried cutting with Wiss snips, per instructions. They distorted the aluminum to the point that I was worried about work-hardening the extrusion. After a little thinking, I realized I had the perfect tool for this in my old Taco Wagon. I scribed the taper line as above and used a hand nibbler to cut, then finished the edges again, as above. I think they're <$30 from one of the tool suppliers.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
