I used the welding cable and the ground strap from the local NAPA store. You don't want a ground strap failure.
Map out what would happen if you hit the starter without the motor case grounded to the airframe / battery.
Cable goes from brass ground lug connected to firewall brace and batt post, to engine case. Strap goes from engine case (different location) to motor mount.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
