Old 10-04-2012, 11:46 PM
crabandy crabandy is offline
Default "Custom ground wrench"
Before I fire up the grinding wheel and torch to skinny-up a 5/8 box end wrench to tighten the top left engine mount (dynafocal1 to fit between engine mount bolt and push rod tube) And a 7/8 with a little more bend for the spark plugs what have others done?
Old 10-05-2012, 12:55 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Yep... a ground away 5/8 Craftsman wrench is now in the modified tools section of the tool box...
You probably don't want a HF one for this job.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-05-2012, 08:25 AM
Rupester Rupester is offline
Default Fear not ...
You'll likely be able to use the ground 5/8 wrench again when it comes time to tighten the wing bolts.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
