10-04-2012, 09:49 AM
The Dynon servo mounts look identical to the TTrak. I drilled a small hole in the lower bracket and tied to that.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
10-04-2012, 04:18 PM
Is it possible to drill the thread out and put a bolt with nyloc AN 365 and 910 washer right through the servo box? I have the same problem and was looking at that as an easy solution.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
10-04-2012, 07:49 PM
Originally Posted by Kahuna
As mentioned, search safety wire on EAA's website and you will find some neat stuff.
This EAA video has some great advice on safety wiring.
10-06-2012, 12:14 AM
Thank you, ALL, for some great input! I can see that there are a number of good options here.
Originally Posted by flion
Dingdingdingding! Kurt has hit the answer according to TruTrak. The instructions for the roll servo specifically call out "Install either internal lock washer or AN960-10 washer with safety wire". <edit>
Patrick, you're quoting from some instructions that I don't seem to have. Where is this set of instructions you're referring to? I bought my brackets from TruTrak and I have printed drawings, but no references are there to any hardware, or the instructions you quote.
Bruce, thanks for the link to the video. Excellent!
10-06-2012, 08:05 AM
TruTrak has manuals and specific installation instructions online. There's a small link at the bottom of the website that is easy to overlook. It's easy to overlook, so here is the link: http://www.trutrakflightsystems.com/docs.html and you'll find RV installations listed to the right. Not all the installations are as detailed as the RV-10 roll servo (the pitch servo instructions are a picture without measurements even, for example) but you can find threads on here dealing with issues and TruTrak does participate here. I've also found their support to be quite good.
EAA Technical Counselor #5357
10-06-2012, 10:27 AM
I safety wire all three heads together, but I did it with the servo on the bench. I then installed it into the wing. This was a long time ago, before they were even telling you to use drilled bolts. I haven't seen the newer instructions, but they sound better  Boy, I'm starting to sound like one of the old-timers....Yikes
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
10-06-2012, 10:45 AM
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
10-06-2012, 08:18 PM
Maybe something different ...
I think I remember the hole being threaded all the way through the servo. On my 7, I just got a machine screw(s) (#10 as I remember it) that was fully threaded and ran it all the way through with a lock nut on the back. Maybe I ran a tap through it, that was several years ago but it is bolted and "nutted" on my airplane.
Bill S
7a Ark
10-07-2012, 04:35 AM
Well, after looking at a number of ways to safety this bolt, this is exactly what I ended up doing. Getting into the tight space between the wing ribs, working through this small opening with my big hands proved to be difficult enough. Let alone trying to work with my safety wire pliers, on the back side of this servo. So I took the servo out and ran a #12 reamer all the way through this hole, and simply installed an AN3-12A bolt, 910 washer and locknut. I checked for any clearance issues with the pushrod that will go on here, and there's no problem. Now I'll safety the two bolts on the bottom-front in the regular way to finish this.
Thanks again for all the help. I found those excellent videos on EAA's site, and Joe, thanks for the document! I'm saving it for future reference.
.JPG)
10-07-2012, 05:34 AM
Loctite
BTW, red loctite is very strong, blue is the medium hold. There is also a Stud and Bearing mount that is forever. Gene
