View Poll Results: Do you have one of the following on your IO-540
SlickStart with the LH mag a retard mag? 7 50.00%
No SlickStart with two standard mags? 0 0%
Impulse mag on the LH and standard on the RH? 0 0%
Other? 7 50.00%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Old 10-02-2012, 08:40 AM
Janekom's Avatar
Janekom Janekom is offline
Default SlickStart on IO-540
We have installed a SlickStart on our RV10 as the engine came with a retard magneto on the LH and a normal magneteo on the RH.
As things happen it just died on us and it is expensive. Up to now I have planned flights not to have hot starts ( as that is where the problem comes in) and cold starts without the SlickStart is a non event. I had to change the wiring temporarily and impliment a separate start switch and have the mag witch on "both". This is while I am waiting for a new unit.
I would like to know from others with an IO-540 if they use the SlickStart with retard mag, impulse mag on the LH or just two normal mags.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
Old 10-02-2012, 09:05 AM
Wesael's Avatar
Wesael Wesael is offline
Default Other
We have the lightspeed ignition wired for starting and a bendix mag on the right side with no mechanical impulse coupler to fail. However there are no provisions for starting if the battery voltage is below the 6.5 volts required by the lightspeed.
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
I have changed my User Name to the correct spelling as it became availible. Please direct all correspondence to Weasel
Old 10-02-2012, 09:20 AM
barryrv10 barryrv10 is offline
I have a RV10 with IO-540, Slickstart with Retard Mag and normal Mag for the first 150hrs; had no problems with hot or cold starts. I now have the Slickstart with Retard Mag and EIS Elect Ignition and have no problems with hot or cold starts; I'm now at 350hrs. I spoke with a Slick Mag Tech and he said Impulse Mags were not recommended on the IO-540 because of vibration issues and failure of the impulse coupling. I have the troubleshooting info for the Slickstart if you need it
Old 10-02-2012, 09:58 AM
rleffler's Avatar
rleffler rleffler is offline
I have a G3i ignition, which provides similiar functions in the starting process as the SlickStart. I have a retard slick mag on the left. First engine start is planned for early November.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-02-2012, 10:01 AM
jchang10 jchang10 is offline
Hmm, i have the same setup as Jan. How many hours did you get out of the Slickstart?
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 10-02-2012, 11:43 AM
Janekom's Avatar
Only 130 hours and I have bench tested it and it is DEAD!
It is not just the price - when this thing fails in a remote place ( we have plenty in dark Africa! ) you are in the dang big time.
The problem is that while you are cranking with a faulty SlickStart, you just flood the engine and you do not realize it.
The hint is this - when you find that it is firing or even starting (if you are lucky), the moment when you release the starter, you have a dead SlickStart. Talked to someone with a Pits Special and he did not realize he had the same problem until I told him my story.
Jan Hanekom
South Africa
Old 10-02-2012, 12:22 PM
I would advise caution starting on the right mag. Without a retard breaker there is a good chance of kickback on a start attempt.
I am surprised this works at all. With no impulse coupler it is hard to generate enough voltage at low rpm.
Old 10-02-2012, 12:59 PM
Wayne Gillispie Wayne Gillispie is offline
I have 85 hours on my slick start/LH retard mag. I tested it at installation and will test at each annual. I tested by disconnecting starter, removed 6 bottom plugs, had someone turn A510-2 keyswitch to "start" and held it there. Then I rotated prop through. Each plug lead will jump a 3/8" gap in firing order sequence for several degrees of rotation.
I have had a difficult time with every hot start and have tried different techniques. I would hate to try to hot start it without the slick start.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 10-02-2012, 01:18 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Flew Nearly 100 hrs - Miserable Experience
The RV-10 would absolutely not "hot-start" --- we flew nearly 100 hours, always having to get "jumped" if we stopped for any period of time. I finally learned that the engine (0SMOH) with no impulse on the left and none on the right needed a "Slickstart" ------- I installed a Slickstart, and life is beautiful again.
Old 10-02-2012, 02:45 PM
9GT's Avatar
9GT 9GT is offline
bob
I think your going to like the G3i ignition. We put one on my buddies IO-360 Cozy MkIV this summer and it really smoothed out the idle and burning about 10% fuel at cruise. I plan on one in my -10 after I get it flying. I put a Slick Start on my C-152 and it really improved starting the little O-235.
David C.
Howell, MI
