Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 10-01-2012, 09:34 PM
bruceg bruceg is offline
Default IFR GPS Installation Documentation
After installing and testing a Garmin 430W in an experimental aircraft in accordance with AC 20-138, what is the proper way to show compliance with the AC? Should it be a logbook entry or a more detailed supplement to the aircraft paperwork?
Thanks!
Old 10-02-2012, 06:11 AM
Walt's Avatar
Walt Walt is offline
AC 20-138c "is for aircraft manufacturers, avionics manufacturers, installation shops, or other applicants seeking design and/or airworthiness approval for the positioning and navigation systems described in this document".
Installtion of a 430W in an experimental aircraft is accomplished per the current installation manual and AC 43-13. You can reference the Garmin 430W STC in your entry, however, the STC does not include experimental aircraft so it's really not applicable.
The average installer is not equipped to apply for an airworthiness approval (STC) per the AC, and besides Garmin already did that all that for you with their STC.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-02-2012, 04:10 PM
Thanks Walt, that makes it easier than expected
Bruce G.
RV-8
