Keep VAF
Going
10-01-2012, 06:15 PM
wire panel to a single connector
AMP 37 pin connector is full. now I need another one.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
10-01-2012, 07:41 PM
I used a 63 pin Amp CPC connector, plus two 12-pin Universal Mate-N-Lok connectors for power and ground connectioins to the panel.
I don't switch any power on the panel, all that is done with a relay tray in mid-fuselage. This allows me to route 22 AWG control wires rather than larger power wires.
The UML connectors carry redundant grounds and power for the avionics.
V e r n. ====
RV-9A complete
Harmon Rocket complete
Member of OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
10-02-2012, 06:30 AM
that is a neat idea
that is a neat idea.
Steve Melton
Cincinnati, OH
10-02-2012, 12:19 PM
wiring single source
Vern, do you have any pictures or diagrams how that lays out. That sure would cut down on connectors if you want disconnectabilty with the systems.. Thanks.
10-02-2012, 10:44 PM
panel power wires are 16 gauge
all of my power wires on the panel and from the panel are 16 gauge. that makes getting all the wires in a squeeze.
Steve Melton
Cincinnati, OH
10-03-2012, 08:20 PM
Here's a link to my Rocket schematic. You will need to download the Express PCB application from here.
Note: I don't have the time to answer any questions about this schematic ... you're on your own.
V e r n. ====
RV-9A complete
11-26-2012, 04:06 PM
now two connectors for panel
wiring complete. two bundles each side by side allowed enough room for cover to clear. that's a lot of wire! now to insulate the firewall. I have the heavy ceramic insulation recommended by Dan H and I thinking of how best to attach it to the firewall.....
Steve Melton
Cincinnati, OH
11-26-2012, 07:36 PM
CPC Connectors
Steve, beautiful work.. Using the same connectors on my 9A, fortunatly I work for the company that manufactures them.. I do have a question, do you have any pictures of the back of your panel? I would like to see how you connected off of your switches, instruments and indicator lights to the CPC connectors.. Thanks,
Mark C. RV9A
11-26-2012, 08:32 PM
Steve, I am just getting to this part of the build. What I need is about 50 pictures of every wire you have done! Isn't there some sort of rule that if you know what you are doing you are required to post pictures so those of us who don't can copy? That was my understanding!!
And Mark, if you make those connectors, you should be able to slip a handful or two into your lunch bag, right?
I may get my plane wired after all!!
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
11-26-2012, 08:50 PM
wiring is patience times five
for me the wiring was patience times five because that is how many times I did it over.
backside of instrument panel
http://www.vansairforce.com/communit...ide+instrument
Steve Melton
Cincinnati, OH
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
