Old 09-30-2012, 01:42 PM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Default Honda S2000 starter switch wiring
For those of you who have or will be using a Honda S2000 start button how did you wire it. I don't need the annunciation light or fancy gadgets just push the button and it starts. I am also using a VP-X so the wifi no will look like a wire from the Vpx to the button and then from the button to the start solenoid.
Thanks in advance
-David
RV-7 N87DX Built, Flown, and Sold!
Old 10-01-2012, 12:21 PM
UnPossible's Avatar
UnPossible UnPossible is offline
I have this exact combo on my plane (VP-X and S2000 starter switch) and it works well.
I ended up using a secondary 12V relay from the autoparts store.
One thing to be careful with, is that it matters which side of the s2000 switch you send power to. I had to have have an electrical engineer buddy with an ocilliscope come and help me troubleshoot some weird starter issues I was having.
When we switched around the leads on the s2000 switch, everything worked fine. Below is a sketch of the wiring diagram I used. Take a look at some of the s2000 intallation DIY guides to determine the direction to send power through the switch and you should be fine.
Hope this helps,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
