09-27-2012, 05:58 AM
Two Location Build
Can any of you experienced builders help me with a decision. I am thinking about a build of a RV14 or RV10. Since I am at my work location during the week and 75 miles away at my home on weekends, is there a recommended split between kits to optimize my time? I do not want to loose time by only building at one location. My primary shop would be the weekend home and my secondary would during the week. Any recommendation on which kits to work on simutaniously? Or is this a bad idea?
09-27-2012, 06:28 AM
Theoretically you could do so but you'll likely need to buy multiple sets of equipment and tools to do so. There are two options. First, cart parts back and forth that need deburring, fabrication, etc and focus on large structures at a single location but that's going to get old really fast. Second, you could double up your large equipment (expensive), cart your small tools back and forth, and work on the empennage at one location and the wings at another provided you have the space. You don't need to bring all of the substructures together until later in the build.
John Qudeen
RV-9A Fuselage (ready to roll the canoe)
N211EG (reserved)
09-27-2012, 06:29 AM
Deburr
To keep the number of duplicate tools down, I would just have a stack of parts at the workweek shop, and just deburr there. As your parts are deburred bring them home to be ready to assemble. You could also scuff (if you are priming) there. That limits the number of tools you need to a small amount. If you get too far ahead on deburring, you could also bring cleco's and a couple drill bits, and do the first assembly, match drilling, and hole deburring there as well. Then bring home to prime (if priming), final assemble and rivet. That way you are mainly transporting small pieces, and you don't need duplicate air compressors, rivet guns etc. The majority of the skins at least for the tail will fit in a car well. At least 50%, probably more like 80% of your time is spent on the deburring and match drilling, but it requires very few tools.
09-27-2012, 06:55 AM
I think John has the best approach of working on different parts of the project at different locations would be the easiest to facilitate. However, there will most likely require additional tools, like an air compressor that would need to be purchased.
I wish you luck. I have only 12 miles between the garage where I started the build and my hangar. There have been days where I had to make the trip multiple times due to something I forgot. Even though it's only 12 miles making that trip daily after work gets old very fast. Especially during the winter months.
bob
09-27-2012, 07:04 AM
Kind of what the others have said. Even though I completed the subassemblies in my home walkout basement shop and final assembly at the hangar 45 miles/ 1 hour away, I needed multiple sets of tools and a 2nd air compressor. It was cheaper to buy the tool I needed (but was at the opposite location) than travel the 90 mile round trip to get the one tool I already had.
Noel
RV-6A N6NF
tip-up
flying
09-27-2012, 07:23 AM
VAF Moderator / Line Boy
The elephant in the room regarding "building time" is the many, many hours spent researching, reading instructions, mentally building parts before using your hands, and ordering things like avionics, FWF stuff, interiors...you name it. While I frequently tell people that my build logs (accurately) show 1024 hours to get my RV-8 flying, this doesn't account for the thousand or so "thinking" hours spent on the project. Just something not consider during the week when away from the shop.
Of course, the suggestions in the above posts are also quite valid - nothing like deburring a stack of wing ribs while watching TV....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
09-27-2012, 09:59 PM
Sent a PM. Check your messages.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
09-29-2012, 01:00 AM
I work in Hong Kong and am building in UK on days off/leave. During the earlier build stages I would take ribs, stiffeners and other small parts and prep them them in my flat.
I had a drill with a scotchbrite wheel, some scotchbrite pads, tin-snips, hacksaw, a set of model files etc - just enough to get by. It was a bit monotonous but I got a lot done - as a bonus, it kept me out of the pub in my spare time
And, as someone else mentioned, a lot of reading, thinking and research.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
09-29-2012, 10:22 AM
Portable shop an option
What kind of transportation do you have? Pickup, small trailer?
I have a pickup and have no problem transporting the essential workshop items on wheels. My compressor has wheels; my large tool box from Harbor freight has wheels. I use also a portable EAA workbench which i set up on a pair of good quality saw horses. I use a set of tailgate ramps also from Harbor Freight to get the heavy items in the truck. Breakdown and set up is only minutes. If you don?t have a truck, a small trailer would work fine. Ryobi bench top band saw and a bench top grinding wheel for the 3m deburing/polishing wheel are also part of the deal. I built my empennage in another location and moved the tools easily.
Al Girard, Newport, RI
N339AG
RV-9
09-29-2012, 02:47 PM
Empennage in a jig at home, wings in a jig at work...that sounds pretty heavenly to me. Yes, you will need a second compressor and some tools but if you are considering building an airplane, believe me that money spent will not stand out in your mind when you are done. Could have a tool box with the expensive hand tools in it if you wanted to save some tool money (squeezer, drills, etc)
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
