Old 09-22-2012, 08:32 PM
Michael Burbidge Michael Burbidge is offline
Default What is this on my intake pipe?
My O-320-D3G is used. It has some sort of probe on the intake pipe of cylinder number 3. Here's a picture of it. Do you know what this is? Maybe it was where they were taking the manifold pressure from. The primer port on cylinder number 3 had a plug in it. I'm now taking my manifold pressure from there per the Vans manifold pressure gauge instructions.
This is ugly and I'd like to remove it. How's the best way to plug it? I'm thinking of plugging it just like they have attached the probe.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 09-22-2012, 08:38 PM
It looks like a port for an emergency vacuum system (need to run part-throttle so intake pressure is less than outside, then use the pressure difference as a vacuum source if your dry vacuum quit.) If my guess is right, you want to plug this up, otherwise that cylinder will always run leaner than the others.
Old 09-22-2012, 10:04 PM
DaAV8R DaAV8R is offline
Yep. That is part of the SVS standby vacuum system. As stated above, this provides an emergency vacuum source but did require less less than full throttle to provide 3.5" minimum pressure difference.
The part can be seen on the site listed below.
http://www.thevacsource.com/parts.php
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 09-23-2012, 07:38 AM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
My first choice would be to replace that tube instead of trying to plug it. Second option would be to weld the hole.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 09-23-2012, 12:35 PM
randyintejas's Avatar
randyintejas randyintejas is offline
Yep, TIG it up.. That is why I keep my TIG Welder around and for all the little Opps in the build process
Edit.. I would put a steel backer in there before I weld that so the material stays flush and does not dip down into the air stream.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 09-23-2012, 11:33 PM
Default Replacing it...
I think I'll just replace it. I don't TIG weld. I can get one from aero stock for $64.
Thanks all
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 09-24-2012, 12:54 AM
gasman gasman is offline
Brass would work better as a back-up..... Finished plug would be flush inside and outside.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 09-24-2012, 05:00 PM
chaskuss chaskuss is offline
Mike,
Email sent regarding a good used intake tube.
Charlie
Old 09-24-2012, 08:19 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Agree to just replace the intake tube rather than try to patch it.
Neal Howard
Airplaneless once again...
