Old 09-22-2012, 01:07 PM
Michael Burbidge Michael Burbidge is offline
Default How does my starter cable routing look?
I'm just beginning work routing and securing wires forward of the firewall. One of the first wires I secured was the starter cable from the starter contactor to the starter. I wanted to get some feedback on whether the way I've secured and routed it is appropriate. Here are some pictures.
Beginning with the contactor which is in the standard position.
I route it straight from the contactor to the engine mount on the lower opposite side of the engine.
From there the wire takes a gentle half loop and is attached further up to the next engine mount support bar.
Then it goes inside the intake manifold pipes and the exhaust pipes up to the middle-side sump bolt.
Finally it goes from the middle sump bolt to the starter.
Each of these hops is about 10 inches long. The last hop is more like 8. The cables are the welding-type cables from B&C.
What do yo think?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 09-22-2012, 01:40 PM
RV6_flyer's Avatar
Very clean and professional installation. Looks almost like a certificated airplane.
Someone is likely to say to put a "boot" over the connections to prevent shorts in case something falls on it. I have no problem with it as it is as this is an intermittent circuit that does not continuously have power applied to it.
IF you want an award winning airplane, the boots will get you extra points.
EAA TC
FAA A&P
FAA DAR
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-22-2012, 01:43 PM
NYTOM NYTOM is offline
Wink Thanks for the guide
Michael for what it's worth I going to use your photo's as a guide when I wire mine. Looks great!
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 09-22-2012, 04:25 PM
Default Have boots...
Thanks. I do have the boots and plan on using them for the final install.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 09-22-2012, 06:47 PM
az_gila's Avatar
az_gila az_gila is offline
EAA TC
FAA A&P
FAA DAR
A "standard" boot at the starter end is going to look tacky because of the 90 degree terminal at that end...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-22-2012, 09:39 PM
Wayne Gillispie Wayne Gillispie is offline
I installed a flat ss standoff at sump bolts then installed #2 ga starter cable on bottom and alternator 6 ga on top.
Soldering all of your fat cable terminals will provide better connections.
Mark and remove oil drain back tube clamps to trim off excess then smooth edges. Saves weight and makes working around those areas easier/safer down the road. Retighten these after 10 flight hours.
Keep truckin, not much longer.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-23-2012, 01:11 AM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
In your last picture, I see you have a 90deg crimp connector. My plane 'ate' (broke) two of these early on (vibration) before I changed the cable to a 'straight' crimp connector with a big loop coming in from the side. Either way, a boot is a good idea Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 09-24-2012, 10:37 AM
RKellogg RKellogg is offline
Default 90 degree vs. straight terminal
Rosie has a valid point. The roll vibration will quickly fatigue the ring at the starter in bending. I'd better take another look at mine... - Roger
Old 09-24-2012, 11:59 AM
rocketbob's Avatar
I always want to see a service loop at both ends to allow for inevitable changes. For example, if you decided to go with a different starter down the line (lets say your starter quits in the middle of nowhere, and your only choice is to use a different one), with a service loop you have some flexibility there (pun intended.) Same goes at the contactor end. Generally there should be an adel clamp to support the loop so that vibration in the wire does not cause a premature failure of either the terminal or the bolt.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-24-2012, 12:44 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default give blood
Originally Posted by Michael Burbidge View Post
What do yo think?
What's the red stuff on the drain back tubes? Is that the donation to the hose clamp gods that Wayne was referring to when he said to trim the clamps?
Mickey Coggins
http://rv8.ch
"Hello, world!"
