Old 09-22-2012, 07:17 AM
bkthomps bkthomps is offline
Default Flying new panel at night
Took the RV4 out last night for some night XC time behind the new panel/AP now that I've done about 10hrs of day VFR with it verifying everything works
Here's some shots, still fine tuning a few bits but so far it's a blast to fly. If you haven't upgraded your panel yet, hopefully this is some extra motivation
Old 09-22-2012, 07:47 AM
panhandler1956's Avatar
That is too cool! Really makes it nice at night!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 09-25-2012, 06:13 AM
BillFear BillFear is offline
Default Very nice
I love the high quality resolution that the new skyviews seem to have.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
RV6_flyer's Avatar
Very nice. I am thinking about doing an upgrade but have one concern. How is your night vision with all the "white" light that the "glass panel" puts out?
ADS-B will be required in 7-years to use the airspace the way I use it now. The airplane will be over 20-years old then and an update would be in order.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-25-2012, 07:23 AM
the screens dim very nicely, i haven't had any issue with night vision, i have a strip of red LED's that fires down from the canopy bow that I use as well, the mixture of these two light sources gives me all the visibility i would need
Old 09-25-2012, 03:04 PM
flion's Avatar
flion flion is offline
Speaking in general, because I'm flying a different EFIS, I am more comfortable at night with a glass panel than the steam gauges. I have always found the steam gauges difficult to read in a low-light setting; even a good lighting ring leaves dark areas. Shining a light on them usually makes it worse as the reflection off of the glass just makes them harder to read. On the other hand, a glass panel is easy to read, even at extremely dim settings. At about 40% dim, I can look out my RV cockpit and see perfectly well if the night conditions permit. On a moonlit night, that means seeing terrain reasonably well. However, a glass panel in a C-182 made it difficult to see across the cockpit and out the other side, so I believe placement is a potential factor. In the RV, there is no direction to look out of the cockpit that puts the panel directly in my line-of-sight.
EAA Technical Counselor #5357
Old 09-26-2012, 07:42 AM
i agree with this, it's very easy to control the DIM setting and it is simple to read this screen versus the steam panels i've flown in the past
Old 09-26-2012, 09:01 AM
Brian,
I am building a -9. I was working on the wings and found a great deal on a mostly complete airframe. I thought I had time to learn about what I wanted in a panel but now I have to start making choices. Your panel looks great and I have heard good things about the Skyview. Do ylou have a full picture of your panel or a list of what you have installed? I am confused when I try to understand what options I need to add. There is a list of many items I can't figure if they are included or not.
I would love to have your dual screen setup. Do you have a lock on your plane and where is it parked! haha!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 09-26-2012, 09:18 AM
It is a dual 7" skyview, dual adhars, dual backup batteries, dual alternators, PAR100EX with radio, G430W (dual radios)
I can tolerate a failure of any of the components with this configuration, and it's a LOT stuffed into a RV4, but is still most likely lighter than my previous panel
Old 09-26-2012, 09:30 AM
thanks, that helps. Wow, you got it in a 4. Good planning!
rockwoodrv9a
Williamston MI
O-320 D2A
