Closed Thread
Old 09-21-2012, 10:51 AM
flyingj flyingj is offline
Default bending a replacement belly skin (advice)
I have an old RV3 kit and the original builder damaged the tail belly skin. As many of you know, these are tapered, and have curved bends for the lower corners of the fuselage. Additionally, the curve itself has a larger radius at the forward bulkhead/former and smaller radius at the rear.
What techniques and tools are required to make this skin?
Jim Frisby
Palmer AK
Sorry, I should have posted this in RV Building Tips/Techniques. Hope it's not a problem but I'm creating a new thread there because I don't know how to move a thread.
Last edited by flyingj : 09-22-2012 at 08:02 AM. Reason: meant to post in RV Building Tips/Techniques
Old 09-21-2012, 01:41 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Jim,
This would be a good start. http://www.averytools.com/prodinfo.asp?number=KIT-100
But there are a lot of RV builders in AK... I would try to find help on it.
You could start here with inquiries... http://www.eaa42.org/ An experienced builder could save you time, grief and $$$
HTH,
Jerry
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Closed Thread
