Old 09-18-2012, 05:10 PM
macrafic's Avatar
macrafic macrafic is offline
Default New AFS Magnetometers?
I had heard recently that AFS came out with new magnetometers, and that the old ones are no longer a viable combination with the new EFIS's. I'm looking for any information on this (trying to understand how they changed and why), but can not find any, either in general or on the AFS web site/forums.
Anybody have any information on this?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 09-18-2012, 05:59 PM
N402RH's Avatar
N402RH N402RH is offline
It is actually a new higher performance AHRS unit that is remotely mounted.
Model ___________Roll Rate (max)___________G Meter
Crossbow 525________200 deg/sec______________4 G?s
72010 AHRS_________500 deg/sec______________8 G?s
The new 72010 AHRS mounts in the same location as the current Crossbow Magnetometer using the same holes and wiring.
Rob Hickman
Advanced Flight Systems Inc
Old 09-18-2012, 06:03 PM
macrafic's Avatar
Rob Hickman
So, Rob. Is the new AHRS unit a separate unit from the Magnetometer, or have they been combined? And, what are the benefits in going with the remote AHRS unit vs the older embedded unit? Thanks for jumping in on this!
Rochester, MN
Flying
Old 09-18-2012, 06:11 PM
Brantel's Avatar
Brantel Brantel is offline
Rob,
What is the physical communication link between the remote unit and what protocol is handling the data?
(edit) I just saw that it uses the same wiring as the original magnetometer.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-19-2012, 09:35 AM
N402RH's Avatar
The new unit has the AHRS and Magnetometer in the same module.
The new AHRS has much better performance.
Rob Hickman
Old 09-19-2012, 10:57 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
The nice thing about them being combined is the installation is much easier. There is no longer a requirement for the EFIS and the ADHRS to be precisely aligned with each other (fractions of a degree were required before).
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 09-19-2012, 12:05 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Upgrade?
Rob - Is there any benefit to upgrade my 4500 with this new magnometer/AHRS? Is it even possible? Or is this just for the 5000 series units?
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
