That's where I've got my ADAHRS and I've measured 3* difference from "no cable" to "cable draped over the ADAHRS".
Given it is still around 8-10" away in normal operation - ie when you're wearing it - it isn't a problem for me. YMMV though. Bear in mind the Dynon can compensate, within reason, for static magnetic fields, so even if your cables are causing a bit of an issue, if you can have them held in the same position each flight with an occy strap or something, that may prove a viable workaround.
Aligning the ADAHRS and testing magnetic interference.
