Check propperly!
Hello
I ran into the same on my RV-7A. One rivet I put in the wrong way around. Check the drawings, where they show the F-7101-L/R Gear Attach Web. Look for the lowest rive that the web/center section, this one should be installed flush on the inside.
Then I countersunk all the hole that sould give the rivet head space, on my parts, the position of the hole where off by a small amount. By looking close we found a missing hole that gives way for the rivet head. I informed Vans but they did not react. A buddy found the same a year later. it is on your first image, on the right side, the 2nd row of rivet-hole, the steel is cut at an angle, but it does not pass the rivet fully. We needet to file a half circle.
Do not forget the washer under one screw hole! There is one screw that goes throu the gearleg weldment into the spar, but on a position, where the doubler on the spar is shorter.
Regards, Dominik
Reason: spelling and adding more information.
